Hi newbie working with Arduino and VISA
Hi everyone, basically I have the arduino running ROS framework on it, and I need to set up a Labview interface to override the firmware. that part of the firmware code looks like this
void Tdsae::ak(const std_msgs::Float64ConstPtr &msg)
    std_msgs::UInt16 driverMsg;
    driverPub.publish(driverMsg);
and my labview code looks like this,   it seems the labview code failed to override, and I dont really understand why
(5,109 Views)
Hey alexishiyu,
Is there a particular reason you are utilizing LabVIEW to override the firmware as opposed to sending text-based commands?
Unfortunately, without seeing the actual ins and outs of what is being sent to and from as VISA commands, it will be a bit hard to diagnose what is going on.
Finally, I would also like to lead you to the LabVIEW MakerHub, a forum and community dedicated to using LabVIEW with some third-party devices.
The forum for controlling Arduino (using LINX protocol with LabVIEW) may also be a good place to post your question, as that community is generally a bit more geared towards Arduino/Raspberry Pi/etc.
Tanim I.
(5,067 Views)
Hi Tanim,
Thanks for your reply! So in Labview I'm sending a string based message, while the string based should have the same format as the message I referenced in the c++ code( so it can override the firmware message)
(5,012 Views)
So it will be a Uint 16
(5,010 Views)
Sorry, it will actually look like
{ uint16 a
 uint16 b}, two separate messages in totally, in labview, I simply concate them, but it doesn't look right
(5,008 Views)
I think I am a bit confused, are you having issues properly formatting your string?
(4,986 Views)
