Hobbyist Toolkit 2024
Hello I would like to use a Raspberry PI and connect it to LabVIEW.
I'm using the 2024 version and have the Hobbyist Toolkit 2024 Patch 1 installed.
My issue is that I cannot seem to find a way to view the Hobbyist Toolkit Functions.
Tutorials and guides say that the once installed I should be able to view the Hobbyist Functions palette but it just doesn't show up.
I found another post about a similar issue where they didn't have the full functionality shown but they still had the palette show up.
Their solution was to install a dir.mnu file from an older version and it seemed to solve their issue but it didn't help mine.
I've also checked to see if it was available in my visible palette selection and it was not there as well.
I've repaired, reinstalled both the hobbyist toolkit and my LabVIEW installation with no success.
Any insight would be greatly appreciated
(693 Views)
Sounds like you installed LabVIEW 64bit which cannot use, therefore does not show the Hobbyist Toolkit.
Also install LabVIEW 32bit to see and use the Hobbyist Toolkit, it will show the Hobbyist menu.
(574 Views)
