How Can I use PXI 7811R to Generate and read IRIG based signals
How Can I use PXI 7811R to Generate and read back IRIG based signals.
(3,990 Views)
Thank you for posting on National Instruments' Forum.
I found a tutorial on IRIG-B implementation in LabVIEW FPGA and I give you a user manual of PXI 7811R.
http://decibel.ni.com/content/docs/DOC-8062
http://www.ni.com/pdf/manuals/370489g.pdf
I hope helping.
Brice S.
National Instruments France
(3,968 Views)
Thanks Brice.
Actually I am having a confusion.
That example uses two R series cards, one for generating and one for decoding.
Why it is not done by using a single card???
And I browsed everywhere in the NI site, the implementation is only for IRIG B and not for the other Timing codes (A, D, E, G, H).
I think we can customize the FPGA code for the other Timing codes, but Hardware wise I am not able to figure out what will be the constraints if I want to use 7811R for both Generation and decoding.
Do you have any idea on this?
(3,951 Views)
Can anyone please help me out on this???
(3,875 Views)
