How can I communicate with RS232 on RTtarget
Unfortunately I am not very experienced using Labview and need your help.
I am trying to commuicate with an massflowcontroler (MFC) with cRIO9074 respectively cRIO9870.
It is working well using VISA, but only if my VI is running on hostPC. Now I tried to copy this into my RTtargetVI and couldn´t find the COM Port using "VISA configure serial port".
Do I need to install driver, so it is working on real-time target?
(4,467 Views)
Hello kzr_kratos,
have you took a look at this post?
http://forums.ni.com/t5/LabVIEW/crio-serial-port/td-p/1145870
Regards
(4,440 Views)
kzr_kratos,
Make sure that "NI-Serial 9870 and 9871 Scan Engine Support" is installed on the cRIO-9074.
(4,438 Views)
