How can I control a Lecroy WaveRunner 6100A?
I have a Lecroy WaveRunner 6100A (the OS is Windows XP) and I'm struggling to connect it to my computer in order to acquire data with Labview 10. I have no GPIB on my computer; I downloaded the drivers from NI website but I'm quite inexperienced and I'm not sure about the steps to connect and configure it via ethernet (especially, how to configure the ethernet connection on Windows XP).
Otherwise, is it possibile to connect it with USB?
Thank you,
Elena
(3,332 Views)
if you have already downloaded and installed NI drivers, you should only connect your ethernet cable and it should work.
If you want to be sure about the possible connections of your device I suggest you to check the datasheet:
http://www.testequipmenthq.com/datasheets/LECROY-WAVERUNNER%206100A-Datasheet.pdf
Have a nice day,
Noemi
(3,270 Views)
Sorry for the late answer, but thank you very much for the help!
(3,109 Views)
