10-29-2007 01:48 AM
10-29-2007 01:51 AM
10-29-2007 05:11 AM
10-29-2007 01:17 PM
10-31-2007 08:07 PM
Dear Mr. Albert,
I have been modified and tested with the example that you kindly did for me. I am so sorry that the power supply drivers are not included in the attached files. I don’t know why they are not included in it. May be my poor knowledge in Lab View.
I
have attached the snap shot of the step voltage power supply program that I modified
your example. When I measured with it, I could not get the step voltage as I wanted.
For example, I want to get voltage start from 0V with step voltages 0.01, up to 10 V and then decrease to -10 V and then to 10 V. The output to the PSU should be
(1)0,0.01,0.02,0.03,0.04,0.05……….9.99,10
(2)10,9.99,……………………………..0,-0.01,-0.02,……-10,
(3)-10 ,-9.9,…………………………………………….+10 V stop and INITIALIZE to zero.
However,
it stops at 2 V and did not continue as I expected. I tried many times in the start Voltage and step size array . I put start voltage 0 V and then voltages as 10.-10 and 10 with same step size 1 V.
My request is what should I modified to get the output as I expect and how can I put the values in these arrays to get for step 1 through step 3 continuously.
Thanks for all the kind help and suggestions for me.
Sophie
11-04-2007 11:05 PM
11-05-2007 06:15 AM
11-05-2007 07:58 PM
11-06-2007 04:38 AM
11-12-2007 07:20 PM - edited 11-12-2007 07:21 PM
