First of all, I'm assuming you are using LabVIEW.
The first you need to do is parse the string returned by the instrument.  In this case you need to search for the known symbols in the string (like the euro sign) and chop the string to get the numeric strings.  Here are some examples on parsing from www.ni.com:
Keyword Search: parsingOnce you parse the numeric strings you can use the "String/number conversion VIs" in the String pallette.
Hope this helps.
DiegoF.
Message Edited by Molly K on 02-18-2005 11:01 PM
