How can I get LabVIEW to acquire more than 1250 samples using an Agilent U2720a oscilloscope?
I am trying to acquire a large amount of data (on the order of 25M data points at 50MHz) using an Agilent U2702A oscilloscope and LabVIEW 8.5.  However, I can only collect 1250 data points.  I am able to change the "TimePerRecord" (total time length of the signal), and the sampling rate changes accordingly to match the number of data points, which I cannot figure out how to change.  Does anyone know how to do this?  The VI is attached.
(3,183 Views)
