How can I get MAX in my virtual machine to recognize my DAQ?
I am trying to control a DAQ through a windows XP virtual machine. The error message I recieve is as follows:
Error 200220 occurred at DAQ assistant
Possible Reason(s)
Device identifier is not valid
Device Specified: Dev2
Suggested Device(s): Dev1
Naturally, it seemed the solution was to specify Dev1, and that I could do this through the MAX. When I go to Devices and Interfaces in the MAX I don't see any devices listed.
The DAQ is recognized by the windows device manager, but the driver selected is C:\WINDOWS\system32\DRIVERS\nixsrkw.
I read in my search for a solution that I should try to change my driver to ausbtmc.sys. I following instructions to update the driver using a 'browse from file' option, I found I was unable to select (or even see) the .sys file.
Does anyone have an idea for what I can try? I am a labView noob, I would greatly appreciate specific instructions if you can help.
Thanks!
Leith
(4,894 Views)
Virtual Xp machine will not address hardware.
(4,865 Views)
Hello LeithZ,
I got a very similar issue and it was solved by a Win XP hotfix.
See:
http://digital.ni.com/public.nsf/allkb/EDA23D2970BD16C6862577D70006E3CA
I hope it helps.
(4,819 Views)
