How can I have two LabVIEW exes share a COM port?
Does anyone know how to let two executables share one VISA COM port? (I don't want to build them into the same application.)
Thank you,
Dave
(3,865 Views)
If your environment is Win32, the system does not allow multiple processes to open the same COM port at a time.  The solution is one of the followings:
(1)Avoid to open the com port at a time.  For example, the first app must close the com port before the second app tries to open it.
(2)Create a separate process that acts as the com-port-access proxy or server.  Your two apps must communicate with the com port through the server process instead of direct access, by using one of IPC (inter process communication) mechanisms.
(3,817 Views)
As a similar approach of (2) I said above, I found a ready-made software - Serial Splitter.
This software looks like virtualize multiple com ports being mapped to a single physical port, using Win NT kernel drivers.
(3,813 Views)
