How can I initiate Local Lockout 8722ES using GPIB, Measure and Excel
You are not making much sense to me. What api are you using to talk to the instruments? VISA or low level GPIB? You use a viWrite with VISA to send a command or an ibwrt with the low level GPIB. If you are using low level GPIB, then look at the help for that to determine the LLO command.
Message 11 of 11
(1,154 Views)
