How can I merge two diferent clusters of three into one graph?
Hello.
I am using parts of the (getting started) driver to a Lecroy oscilloscope LC9361. But I have problems  to aqcuire/merge channel 1 and channel 2 into one graph. How can I merge two diferent clusters of three into one graph?
Please help me, many thanks
(3,133 Views)
If I got you right, you can just build an array of both clusters [array of cluster of ...], use the 'build array' node, and feed this to the graph.
Greetings from Germany!<br>-- <br>Uwe
(3,124 Views)
