How can I monitor the GPIB bus with second GPIB-USB-HS (second PC)?
As below, I want to use the Visual studio C# to monitor the command/message on GPIB-USB-HS bus (blue).
How can I use the second GPIB-USB-HS (red) for monitor the GPIB bus (blue)?
Can any one give me a sample code or any information?
(1,828 Views)
Accepted by topic author scottj0403
The functions of the analyzer are provided by NI official.
No programming required.
However, it cannot be used with GPIB-USB-HS.
Products with "+" such as GPIB-USB-HS+ , PCI-GPIB+ , PCIe-GPIB+ are supported.
You can use the GPIB analyzer by marking the red part of your diagram as "+" product.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LM5SAM&l=ja-JP
(1,800 Views)
Thank you for your reply.
Is it possible to use my C# program (not NI officiel Analyzer software) via product "+"? I mean that I want tor write a C# program to monitor the GPIB bus (blue) via GPIB-USB-HS+ or PCIe-GPIB+.
(1,764 Views)
Theoretically, it is possible to make your own by using "+", but it seems difficult because the programming manual for controlling the hardware for analysis on the board is not disclosed.
(At least I don't know.)
(1,752 Views)
