How can I put a "esc" character in the command line of the Iinstrument I/O Assistant?
Hello
I'm trying to prepare a VI for a device (Ultrasonic detector) connected to my RS-232 serial port, and which requires commands and enquires in the format
The problem is very simple....since is a non printable character, how can I put it in the command line of the Instrument I/O Assistant???
Best regards
Massimiliano
(3,219 Views)
Hello Massimiliano,
Thanks for contacting National Instruments.
To answer you question, the best way to do what you are looking to do is to use the instrument I/O Assistant to generate whatever you want the code to do without the non-displayable characters, then once the Instrument I/O Assistant block is on the block diagram, then right click on the Assistant block and select to open the front panel. You will want to choose to convert it to a standard VI, which will allow you to change the code that has been auto generated. In order to add non-displayable characters to this code you follow the knowledgebase link below.
http://digital.ni.com/public.nsf/websearch/77c8f61d36f5a23086256634005acb38
Hope this helps!
Steven B.
Applications
Engineering
(3,219 Views)
