How can I recieve invasive blood pressure data from the patient monitor's analog out put?
Hi
I've got Mindray's patient monitor and would like to get invasive blood pressure data from it's analog output.Is there any tool which can translate the signal so I can get pure data?
Thanbks
(5,814 Views)
Do you know the exact nature of this analog output? NI sells a lot of different DAQ boards.
(5,813 Views)
Thanks for that.
Actually I'm not looking for a tool that just traunsalte the signal,that I can do (I have got a the wave in the scope).
I'm looking for a blood pressure OEM that does the manipulation by itself and just output the systolic diastolic data.
Are you familar with such a tool?
(5,796 Views)
I am not familiar with finished device that receives an analog blood pressure waveform and outputs the systolic/diastolic information.  This would be relatively easy to build using a laptop and LabVIEW, however...
(5,771 Views)
Are you familiar with any companies who might do so?
(5,767 Views)
If you mean companies that might help you make such a device, I would check with our Alliance Partner directory and look for a suitable company or consultant in your area.  You can find the directory here.
(5,758 Views)
