How can I run my GPIB-ENET/100 from MATLAB on an Linux machine?
We want to use MATLAB on a Linux laptop to control a host of GPIB instruments using the GPIB-ENET/100 (Have you ever run MATLAB in Windows? Ugh). We have the instrumentation toolbox. How do we do it?
(3,439 Views)
You can use Matlab to communicate with GPIB instruments. You will require GPIB ENET/100 driver for Linux and you can get it from www.ni.com/linux
The driver comes with two libraries. The shared library is libgpibenet.and it gets stored by default at /usr/local/lib
You can link the shared library to your application to communicate with gpib instruments and using a shared library will ease the transition between different driver version and it won't increase the file size of executable. But if you don't want to use the shared library then a statically linked cib.o file is also available.
(3,439 Views)
