How can I transfer a record of 1M with the DPO 4000 scope?
I am using Labview 8.0 to transfer a record from the oscilloscope via USB. I am able to transfer 10k and 100k points, but when I attempt to trasfer 1M points the read occurs, but there is a warning that not all of the data may have been read. I have increased the read length to 10,000,000 as I am trasfering in ASCII, but different ammounts of data are returned, always about 150,000 points.
The actual data size trasfered should be about 5 times the number of points, because I am using 2 bytes of data per point, and it is being transferred in ascii format. Is there a maximum data trasfer size for the scope or labview over a USB connection?
(3,359 Views)
I now am getting an error out of the visa read, and it is error code -1073807339. This is a timeout error, but some data is being read. Is there a longer visa read that I need to be using or do i need to impose some sort of wait before the read takes place?
(3,353 Views)
Did you use the VISA timeout property node to change it from the default? If not, you can get it on the Instrument I/O>VISA>VISA Advanced palette. The default is 20 seconds.
(3,348 Views)
Thank you very much. I didn't know there was a way to set the timeout. That was the problem.
(3,344 Views)
