How can I turn on a Modbus output in Lookout using a combination of two different data types that both need to be true at the same time for it to execute?
Howdy davidroy,
You will want to post this question in the Lookout discussion forum located here. (As each respective NI Discussion Forum, the Lookout forum is actively monitored by the Lookout support team.) Alternatively, you could send an email to lookout.support@ni.com with your question.
Warm regards,
pBerg
(3,056 Views)
