How can I uninstall VISA from my machine?
I would like to update my VISA from version 2.5.2 to 3.2.
However NI-VISA is not listed anywhere under 'Add/Remove programs'.
I also looked into 'National Instruments Software', but VISA is not listed there, although I'm sure it is installed. MAX shows it and all the dlls are in the system32 directory.
I am running on Windows 2000.
(5,394 Views)
Old versions of VISA could be installed by other programs like LabVIEW or CVI. I would finding old versions of LabVIEW or CVI in you add/remove program list and click modify. It should bring up a list of all of the components that were installed with LabVIEW/CVI. One of them should be VISA, just changes its select to don't install and click next. It should uninstall just NI-VISA.
-Josh
(5,383 Views)
I also have same problem. Unable to uninstall NI-VISA. I could not find Labview or CVI in my Add/Remove program. I am using windows 7 and I am trying to install
INSTALL NI-DAQ mx 9.3.5.
Please help.
Thanks.
(4,580 Views)
In your Add/Remove Software list, there should be a "National Instruments Software".  Modify that and you will get a new window with various NI software to uninstall or reinstall.
(4,577 Views)
Sorry. I do not see it at all.
Anyhow thanks.
(4,574 Views)
