How can i perform parallel port communication in labVIEW?
My friend trying to do parallel port communication with ADC and labview.
which is possible without using any DAQ device?
hariesh
(3,338 Views)
If you have a parallel port available on your PC there is a good example to start from located at Help>>Find examples>>search for Parallel and find Parallel Port Read and Write.vi. Maybe this will give you a good place to start.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,333 Views)
Thanks GovBob 🙂
now i am go throughing the following link.
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
i hope it will help!
hariesh
(3,326 Views)
