How can i use GPIB datan lesen from H34401A(Current)and E3634A(voltage)
Hello:
How can i use GPIB datan lesen from Agilent H34401A Multimeter(Current)and E3634A DC power supply(voltage)?.I use the Labview 6.1.I can only write data to the E3634A use GPIB.I need the helps.Thank you !
Long
(3,383 Views)
I do not know what "GPIB datan lesen" means, but there are LabVIEW driver for both those instruments at http://zone.ni.com/idnet97.nsf/browse/. Just type in the model names (34401A or E3634A) into the keyword field and click "go".
(3,383 Views)
