How could I set the integration time(A/D conversion) of a HP 4284a with labview?
Hi @ all!
I have some problems with the settings of the LCR measurment by using the Hp 4284a(driver agilent 428x).
At the device you could choose the integration time between short, medium or long.
I didn t found a connection between the harware and labview to set this option and use the interface.
Have somebody the same problem and a solution for me?
THX
(3,328 Views)
The driver I downloaded:
Agilent 428X Series Certified LabVIEW Plug and Play (project-style) Instrument Driver
Has the following vi:Public\Configure\Aperture.vi
and the aperture has a connection: Integ Time (0: Short) that can be changed into medium and long
search in IDnet for this driver
greetings from the Netherlands
(3,304 Views)
(3,304 Views)
