How do I control Mitsubishi motor inverter with 4 port RS-485 card and labview?
I have an NI RS-485 4 port serial card, and a Mitsubishi motor control with a RS-485 communication port-I need to know how to control the motor drive using LabView.I have all the motor control parameter codes,but do not know how to implement them.Thanks.
(3,946 Views)
Your best bet is to start with the Basic Serial Write Read example. You can find this by going to the example finder (Help->Find Examples), then selecting the hardware folder, then serial, then basic. You should see the basic example for serial I/O. You can use this as a base to build on.
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,935 Views)
did you found any driver for the inverter?
(3,376 Views)
