How do I control my instrument using C ?
Im interested in writing a C++ program on a Solaris 8 platform to control an Agilent 66312A. Since I'm new to this, I'm wondering if I can do something as simple as:
fprintf(gpib0,"%s","VOLT 5\n"); On this system, gpib0 is the logical address of the GPIB driver card.
Or, is there a more complex procedure required?
(3,490 Views)
Hi Hanna,
To answer your question about writing, it is similar to that. You will use the ibwrt function in the 488 library to do so. There is a great manual at http://www.ni.com/pdf/manuals/320351b.pdf that talks about programming with ni-488.2. Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(3,490 Views)
