How do I control serial power using LabView?
I need to use LabView to alter the voltage coming from the serial port. Is it as easy as writing to the serial port? I know that if you write to the serial port that it'll produce a binary number, does this binary number correspond to a voltage.
(3,796 Views)
The output pins of a serial port are either on or off. The output voltage should be about +/- 12V though you're liable to see some variation but you cannot change a logic one from +2V to +5V for example. There's no mechanism in the pc's UART to do such a thing. The binary output corresponds to a character (in the cse of the Tx line) or a control signal (i.e. Request to Send is either on or off).
(3,795 Views)
So you are saying that it is impossible because the power from the serial port does not vary?
(3,795 Views)
The logic levels vary between 0 and 1. The voltage associated with a logic level does not vary.
(3,795 Views)
If you want to create a scalable voltage value coming from the serial port you must have a Dig -> Analog conversion circuit.
If your goal is to vary a voltage from 1 - 10 vdc, then you must create:
1) a an external circuit that will convert/buffer digital serial interfaced binary values to analog values (ni makes these things)
2) labview code that transfers info to serial port. (driver/etc)
hope that helps!
did that answer your question?
Chances are if you have seen VI in the forest it hasn't fallen.
(3,775 Views)
