How do I determine the interrupt detection sequences for an HP 82350A PCI GPIB card?
I am trying to install an HP 82350A PCI GPIB card in CentOS 6.4. I have installed NI-VISA 5.4.
I tinkered around and found driverwizard in /usr/local/bin. It creates an ini file to control the PCI GPIB card.
I had somehow succeeded in detecting the card (PXI3::0::INSTR). My driverwizard output looks like this
[Module]
ModuleName = "PLX PCI <-> IOBus Bridge"
ModuleVendor = "PLX Technology, Inc."
ModelCode = 0x9050
ManufCode = 0x10B5
SubsystemModelCode = 0x10B0
SubsystemManufCode = 0x103C
VISARegistration = Simple
As you can see, it does not have interrupt handling built into it, so I cannot access it properly.
How do I set up interrupt handling for this card? What are the specifications for the following fields?
Interrupt Detection:
Access Type
Access Width
Address Space
Space Offset
Compare Mask
Write/Compare Value
Interrupt Removal:
Access Type
Access Width
Address Space
Space Offset
Compare Mask
Write/Compare Value
Interrupt Disarm:
Access Type
Access Width
Address Space
Space Offset
Compare Mask
Write/Compare Value
This is the first time I have tried hacking at the PCI interrupt level. At the very least, how do I find out the values for the above parameters? Or at best, straight away what are the values for those parameters?
(4,574 Views)
What does your question have to do with NI? You need to talk with agilent.
(4,570 Views)
I am using the NI driverwizard. So I figured someone out here might have experienced generating a driver ini and inf file for the HP 82350A.
(4,559 Views)
Agilent does not have a linux driver? Why did you purchase it?
(4,557 Views)
Their IO Libraries Suite supports only Windows. Our lab probably used Windows before. This 82350A card is quite ancient. I need to use this because we also have ancient instruments that do not have Ethernet.
(4,553 Views)
