Chris,
Thanks for the check, when you let me know it worked on your machine I assumed the computer serial card was going bad. Went down the hall to a Win98 machine that barfed on the VISA resource name, COM1. However, it worked on ASRL1::INSTR. When I entered that name into my Win2000 Dell, the DTR, DSR, CTS and RTS started working, toggling outputs correctly AND reading inputs. So is this a bug? I've used COM1 and 2 on a lot of serial stuff, always has worked but I've never tried controlling the handshaking lines before.
