How do I highlighted an image?
Hi !
I wish to highlighted an image.
But I can't find the solution at this site.
If you knew the way to highlight an image
Just show me..
There is 8bit grayscale image and i wish to highlighted this image by using IMAQ vision.
I did enhenced the image but I can't find the way to slove this porblem.
I did highlight an image by vision assistant and I found function which is called 'convolution - hightlighted'
But I can't find that kind of function at the Imaq of Labview.
There is a convolute function but there no function which is highlighted.
Please help me to find that solution.
Thank you...
If you need some example. tell me I make it and upload it.
(3,233 Views)
The IMAQ Convolute function should generate the same result as the "Convolution - Highlight Details" step in Vision Assistant. To see this, I created a simple script in Vision Assistant that used that step and then I built a LabVIEW VI from the script. The functionality of this VI is the same as that of the Vision Assistant script.
Try using that function and let me know if you have any additional questions on this issue.
Scott R.
Scott Romine
Course Development Engineer
(3,212 Views)
