How do I make system board the controller in charge
Hi,  I am using visual Studio 2005 C++/CLI.  I have one machine at my desk that is a Windows 2000 machine with an Agilent GPIB board installed.  The Agilent board has been setup to accept NI-4882.NET commands.  I have written an application that, among other things, scan the GPIB bus for devices.  This works well on the machine at my desk.  I have another machine out in the lab that is running Windows XP and has an NI-488.2 GPIB board installed.  When run the application and try to scan the GPIB bus I get an National Instruments exception that "Method requires GPIB interface to be CIC".  I used Measurement and Automation Explorer  to see that the 'System Controller' checkbox was checked and I added a line of code "board->IsSystemController = true" after the board was instantiated with no change and also tried board->BecomeActiveController(true) with no change.  Any Idea on why this error is comming up only on the other platform?
Board^ board = gcnew Board(0);
AddressCollection^ addresses =  board->FindListeners(); //  This line is causing the error to occur
(4,922 Views)
I have the exact same problem and I have tried the same solutions without success.
Why is there no answer to this question (posted in 2007)?
(4,263 Views)
I found something that forces the GPIB board to be CIC..."SendInterfaceClear()" method of 'Board'.
I don't like this though because this causes devices on the bus to change state.
All I want to do when my program starts is to begin controlling.  I don't want instruments to be clearing out their previous settings.
(4,260 Views)
Hi phmoore,
Are you trying to have two controllers on the same GPIB bus?  There can only be one CIC at a time.  Try to get your setup working in MAX by sending basic commands in a VISA test panel, then incorporate your program.
(4,227 Views)
I have only one controller on the bus.  I can run my instruments through NiMax with no problems using "communicate with instrument".  Only when I run this simple code does the problem appear.  You can see where I had to add the "SendInterfaceClear()" to prevent a "not CIC" exception from the "FoundListeners" method. (VisualStudio C# on WindowsXP using NI488 DLL's)
namespace Scanner34970
{     public partial class Main : Form
 {         public Main()
           {        InitializeComponent();
                    List<int> BoardNums = new List<int>();
                    List<AddressCollection> FoundListeners = new List<AddressCollection>();
                    for(int i=0; i<10;i++)
                     try{
                         Board CommBoard = new Board(i);
                         CommBoard.SendInterfaceClear(); // must do this to become CIC
                         BoardNums.Add(i); // add to list of found boards
                         FoundListeners.Add( CommBoard.FindListeners()); // add devices to list of found devices.
                         CommBoard.Dispose(); // get rid of it.
                    catch(Exception exc)
                         textBox_status.AppendText(exc.Message);
                         textBox_status.AppendText(string.Format(" for Board#{0}" + Environment.NewLine, i));
... // more code
(4,219 Views)
Hi phmoore,
Have you referenced any examples?  NI-VISA and NI-488.2 include some pre-built examples that you can use as a template. Take a look in the directory....
C:\Users\Public\Public Documents\National Instruments\
In either the NI-VISA or the NI-488.2 directory there should be and Examples folder with some text based examples to follow.
Unfortunately, my C# knowledge is lackluster, but if I were you I would definitely look for some reference material.
(4,201 Views)
