How do I solve fix this error. Driver Status: (Hex 0xBFFF0011) Insufficient location information or the requested device or resource is not present in the system.
I'm trying to communicate via GPIB to a TkTDS6604
(3,929 Views)
This error is usually caused by an invalid resource name, so if you are using VISA and want to connect to an instrument at address 2 on your first gpib board, use "GPIB0::2::INSTR".
Also, check that you can communicate with your instrument in Measurement & Automation Explorer (MAX). You might also try the interactive control to make sure that the GPIB communication is working.
http://www.ni.com/support/gpib/max/ibic.htm
If this isn't helpful, let us know what development environment you are using and the functions / VIs you are using to try and connect to your instrument.
(3,929 Views)
