How do I use the 9870 to simply retrieve ASCII data from a Laser Range Finder?
I am working on an autonamous vechicle utalizing a LRF (Laser Range Finder). After using Hyperterminal, I read distance values in ASCII format, and now I need to know how to set this up in a VI in labview FPGA. Thanks for any help.
P.S. Is it possible to run a RT VI and an FPGA VI at the same time?
(3,295 Views)
You might find a good place to start is the NI Example Finder. You can get to this from LabVIEW by click on Help » Find Examples. If you search "9870", you should see the example "NI-987x Serial Loopback.lvproj." This example won't do exactly what you want, but it will be a good place to start.
(3,273 Views)
Also, to answer your other question, it is certainly possible to run an RT VI and an FPGA VI at the same time. In fact, almost every cRIO application will do this.
(3,272 Views)
