How do i develop a labview 7 vi to simulate the following HP Basic code: SEND 7;UNL TALK 1 LISTEN 7 DATA
The basic code is used with gpib to cause the gpib card to unlisten then tell the instrument to talk and the printer to listen before sending a copy command to dump the graphics of an HP4194A analyzer.
(4,373 Views)
x0y1z2,
I've attached a LabVIEW 7.0 example illustrating the use of low-level GPIB commands. This program unlistens all instruments, sets up intrument 7 as a listener, instrument 1 as a talker, and then sends a command to instrument 1. Hopefully this is helpful to you.
Alan L.
Applications Engineering
(4,373 Views)
Thanks Alan!! Im aware of the gpib low level commands but the problem here is with substituting the HP basic to the low level command set. In order to do a display dump or use their 'COPY' command I have to be able to put the instrument in a 'TALK ONLY' mode which is accomplished with the HP Basic command: SEND 7;UNL TALK 1 LISTEN 7 DATA.... where as you know 7 is the gpib board, 1 is the instrument talking and 7 the printer/plotter listening... DATA sends the expression value as data bytes according to HP. When running your vi the instrument goes into talk mode but NOT TALK ONLY mode which is different. There must be some differences when using the TALK and LISTEN commands with HP and gpib low level commands. Any ideas?!?!?
(4,373 Views)
I believe the command you are looking for is specific to your instrument. Most likely you can use a GPIB Write (or VISA Write) to send the appropriate message directly to it. Please consult your manual. I hope this is helpful.
-Alan
(4,373 Views)
There is no instrument specific gpib command to do this.
(4,373 Views)
x0y1z2,
Take a look at this link: http://zone.ni.com/devzone/conceptd.nsf/webmain/1D4F87E081CB457B8625680400647625?opendocument
The document describes how to put an interface board into talk-only or listen-only mode. This may be of help to you.
(4,373 Views)
