How do you i get a response from a slave using LIN communication ?
I am encountering some troubles in using the usb-8476 lin network interface. My software consists of labview 8.0 and can driver for ver 2.5.2. and the usb-8476s interface which is a master within lin network and a car dimmer control model which is a slave within lin network. My task is to check if the ouput at each different position of the dimmer is correct. I selected the example "LIN Master Send Header Frame Respond and Receive.vi" to do this.
I am very new to LIN and CAN bus and need to uderstand how to communicate with the slave. I am not sure what i should be entering in "arbitrationID for response","Data for Respone",and "arbitrationID for header"
when  "arbitrationID for response" and "arbitrationID for header" are same,the slave task will respond with same data as "Data for Response" I filled in. How do i get a response from the slave ?
I want to diagnose the lin network,what should I do? if I use the example "LIN Master Send Header Frame Respond and Receive.vi" to diagnose.How should I configure the input parameters? and how I do this task step by step?
I am attaching a screen shot of the data i entered. Hope you find this useful.
Eagerly awaiting for a response.
Thank you.
ANKU
Message 1 of 1
(3,900 Views)
