10-08-2015 01:16 AM - edited 10-08-2015 01:16 AM
I am trying to export a .nitrace file into txt & csv format, and I see that the buffer value is truncated after it gets exported, for example:
| viWrite (GPIB0::20::INSTR (0x053AF520), "CONFigure:WLAN:MEAS:R...", 50, 50) |
instead of
1850. viWrite (GPIB0::20::INSTR (0x053AF520), "CONFigure:WLAN:MEAS:RFSettings:UMARgin 20.00", 50, 50)
How can I make sure that I export the complete string and not just 24 characters?
10-08-2015 09:10 AM
Apparently this truncation dates back at least to 2012.
Someone asked for the ability to not have this happen, but apparently it has not been implemented.
10-08-2015 09:57 AM
Thanks.
10-08-2015 02:50 PM
10-09-2015 03:38 PM
Hi Albert.Geven,
I would recommend posting a new request on the LabWindows/CVI Idea Exchange forum to request updates to this function. We're very appreciative of feedback and feature requests, but unfortunately can't always implement them. In this case, a new thread is more likely to garner attention than the three year old post.
10-10-2015 02:24 PM - edited 10-10-2015 02:25 PM
@TommyDunkz wrote:
Hi Albert.Geven,
NI I/O Trace isn't specific to LabWindows/CVI.
It is an utility that usually installs with NI-VISA.
10-18-2015 12:44 PM
10-19-2015 01:30 PM
Hi Albert.Geven,
Thank you for bringing this issue to my attention. I am looking into it, and will discuss with some colleagues to determine the next course of action.
I apologize if my previous post seemed dismissive. I meant to emphasize that posting on the Idea Exchange forums is typically the best way to bring attention to these issues.
10-19-2015 02:54 PM
@TommyDunkz wrote:
Hi Albert.Geven,
The issue was posted on the Idea Exchange forum.
It may have been incorrectly posted in the LabWindows/CVI section when it should have been more accurate to place it in the NI-VISA section.
Nonetheless the issue is still there 3 years later.
04-25-2017 09:14 AM - edited 04-25-2017 09:19 AM
Hi.
I had the same issue and I wrote myself a tool, that filters the text export from NI I/O trace in that way, that you have your full buffer in one line (CR / LF are replaced). Actually it only displays serial (com-) ports, that are really used (I search for VISA.Close..) and it is written for the german version of NI I/O trace, so you need to replace some constants anyway.
Here it is..
It needs OpenG String/Array installed.
BR
Marcus
