How quickly can I send two write commands using ibwrt(). I seem to be having trouble going faster than 200ms between writes.
There is probably some sort of synchronization issue. It might be necessary to consider writing larger amounts of data and less frequently. Also, another operating system may handle this problem differently. Finally, be sure the latest driver is being used.
Randy Solomonson
(3,144 Views)
