How should a LV driver be?
I developed a MCU based DAQ and control system that communicates with PC via COM port. My client would like to have a driver for LabView. Since I am not familiar with LV system, but I can program in C, so I would like to ask if I can develop the driver as a dll, and if is there any special requirements that I should know?
(3,690 Views)
The best drivers are written in LabVIEW itself, and as you have an interface for a comport, publish this interface and everybody can build a driver.
A normal LabVIEW driver utilises visa for comport access and the rest is sending out a command and interpreting the received data.
greetings from the Netherlands
(3,675 Views)
Hello Daodao,
       If you are interested in developing a LabVIEW Plug and Play instrument driver, check out this tutorial: Developing LabVIEW Plug and Play Instrument Drivers.
Cheers,
NathanT
(3,662 Views)
This same question has been posted in the LabVIEW forum: Duplicate Thread
Hope this helps.
-Ben
WaterlooLabs
(3,652 Views)
