How to apply this lv project?
I had did some modify about the program MAIN_iviDMM_basic.vi and saved into my own space as MAIN_iviDMM_basic_test1.vi,
It can used to measure the DC voltage of the ke2000.
SO,"where" & "How" should I put this MAIN_iviDMM_basic_test1.vi into my Interface Archtecture labview Project?
See attached picture (004.jpg) if I am not  discribute so clearly.
帖子被nicosg在08-06-2007 09:41 PM时编辑过了
Cheers,
Nicosg
anico2127@yahoo.com.sg
(3,758 Views)
I'm a bit confused as to what you are asking...
Can't you just open this modified program?
(3,729 Views)
You want to add the VI you modified MAIN_iviDMM_basic_test1.vi to the project?
How (below)
Select the folder in the project you want to add the VI to
right click and select add file
browse to the folder where the VI is located (which should be on the same folder on disk) then add the file.
For example,
If you want to add the MAIN_iviDMM_basic_test1.vi to the example folder in the project.
MAIN_iviDMM_basic_test1.vi should be in the example folder on disk.
Select the example folder in the project right click and select add file
browse to the example folder select MAIN_iviDMM_basic_test1 and add the file to the project.
Save the project
(3,718 Views)
Hi, Steve.Bri…
Thanks for your reply,What am I doing  is something about interface Archtecture and IVI,the answer was given by jjp377 after you.
Let me know if u still interesting about that.
Thanks & Regard.
Nicosg
Cheers,
Nicosg
(3,700 Views)
Hi,jjp377
Thanks for your reply,I know how to do now ,thanks a lot.
Nicosg
Cheers,
Nicosg
(3,699 Views)
