How to communicate with 2 GPIB devices on same bus
Can 2 independent applications communicate with 2 GPIB devices connected on the same bus to one controller? In my setup the application A communicates only with GPIB device A, app. B communicates only with dev. B. More specific question regarding the GPIB controller driver software is: Will the controller pass the SRQ from GPIB dev. A only to ibwait() call made from the app. A (automatic serial polling off)?
Thx for any help
Sven
(3,876 Views)
If you are using the VISA-API, this should be possible. See the KB:
http://digital.ni.com/public.nsf/allkb/C42CDC77C00E0B8086256E9B0078F887?OpenDocument
(3,844 Views)
It is also possible using the NI-488.2 API.  You will just have to open device level handles (ibdev) instead of board level handles (ibfind).  Using ibwait with the device level handles, will allow you to get the status information for each of those connections.
I hope this helps,
Steven T.
(3,817 Views)
@ Andre_Saller: I'm using the NI-488.2 API on a Solaris 8
Yes, my flow goes like this:
 bd_id = ibfind(boardName);
 ibconfig(bd_id, IbcAUTOPOLL, 0) & ERR ) // Auto polling disable
 // assert interface clear; GPIB board set to CIC (controller in charge)
 ibsic (bd_id);
 dev_id = ibdev(bd_id, dev_addr, 0, T300ms, 1, 0);
 status = ibwrt( m_dev_id, message, strlen(message));
 ibwait(m_dev_id,TIMO | RQS) // wait for service request, or timeout
 ibrsp(m_dev_id, &rsp_byt)
So if I understand you correct the ibwait( deviceA ) will only wait for events from device A.
Similar for ibrsp( deviceA ) it will only read responses from device A. Any stuff from device B will be kept by the NI-488.2 driver for application B in my example.
My current problem is that I get the following error "ESRQ  SRQ line 'stuck' on" in most operations if 2 GPIB devices are connected to the BUS. But so far I'm running just one application which talks to only one and the same GPIB device. All operation work fine if I disconnect the second GPIB device.
Thx  for your help
Sven
(3,805 Views)
Sven,
The SRQ happens when the SRQ line is asserted by one of the instruments.  The ESRQ error happens when an application is waiting for a service request, but one is already asserted for an instrument it does not have a handle for.  This is a problem because the application has no way of serial polling the device and stopping the SRQ that is already happening.  Your application should be modified to give up the processor so that the other application would have time to serial poll the instrument.  Then it can proceed with calling ibwait.
You can get all of this information from the NI-488.2 help topic ESRQ.
Steven T.
(3,774 Views)
