How to configure GPIB board assignments programmatically?
Is there an API or proceedure to configure GPIB-ENET/100 board assignments programmatically on a host PC running WindowsXP?
- or -
Alternatively if there was a way to get the ethernet address, MAC address, or serial number of an GPIB-ENET/100 from only its GPIB board number assignment that would work too.
(3,510 Views)
1) There is no way to programmatically configure your assignments on the XP pc.
2) Here's a possible way to find the serial number based on the ethernet address of that device.
The first eight number of all GPIB-ENET box’s MAC address are the same. The format is 00:80:2F:FF:xx:xx. There is a serial number or bar code number (depending of the version of GPIB-ENET box), usually in a decimal number like 00xxxx. Convert it to Hex, and it will be the last four number of the Ethernet address. For example, if you have a bar code number 008991, the hex equivalent is 231F, so the Ethernet address is 00:80:2F:FF:23:1F. Use the calculated one rather than the one printed on the box.
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,506 Views)
