How to configure the NI5102 communicate using USB under VB6
I using NI5102 communicate via USB by Visual Basic6.0, I have following the IVI configure setting and below error is happen.
IVI::IVIScope::niScope is not a driver session name.
Have any setting I missing?
How can I get data from NI5102 via USB?
The configure page is attach.
(3,147 Views)
It's usually easier to answer questions about IVI configurations if you attach the config file rather than the screen shot - that way we can see all of your configuration information. The IVI Configuration file is typically located in c:program files\ivi\data\IviConfigurationStore.xml.
From your post, I would guess that you are sending the string "IVI::IviScope::niScope" as the resource descriptor to niScope_init or niScope_InitWithOptions. You don't have to qualify logical names in that way - try just using "niScope"
Can you provide some more detail as well about what API you're using to communicate with the device?
(3,141 Views)
