How to control a HP9872C plotter via LabView?
How do I control an old HP9872C plotter via LabView and GPIB?
I assume it is certainly just sending ther right ASCII-characters.
But what are the commands? HP-GL?
I could find anything helpful on the HP website.
Thanks for any hints.
Tilman.
(3,748 Views)
Hi tib
HP9872C should work using HPGL commands.
This is a link about HPGL: http://techref.massmind.org/techref/language/hpgl/commands.htm
This is a link about HPGL converter to Labview (example of commands) :http://hamiltondesign-consulting.com/labuseful.html#Drivers
Hope you can manage to control the plotter with this info.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,744 Views)
