How to control keithley 6221 to change the frequency of a wave at intervals via visa write
I'm very new to LabVIEW. I'm trying to control keithley 6221 to generate a desired sine wave of which the frequency changes at intervals (e.g. 10s).
Now I can use commands below just to generate a sine wave, but i don't know how to change the frequency of the wave 10 seconds later.
SOUR:WAVE:FUNC SIN                      ‘ Select sine wave.
SOUR:WAVE:FREQ 1e3                      ‘ Set frequency to 1kHz.
SOUR:WAVE:AMPL 1e-2                     ‘ Set amplitude to 10mA.
SOUR:WAVE:DUR:TIME 10                 ‘ 10 second duration.
SOUR:WAVE:RANG BEST                  ‘ Select best fixed source range.
SOUR:WAVE:ARM                              ‘ Arm waveform.
SOUR:WAVE:INIT                                ‘ Turn on output, trigger waveform.
SOUR:WAVE:ABOR                            ‘ Stop generating waveform.
Does anybody know how can I do it?
I'll be glad to get any help.
Thanks!
(3,896 Views)
You put a while loop around the VISA Write that is sending the frequency command and place a delay/wait function inside the loop is the basic technique.
Have you looked for a driver? Help>Find Instrument Drivers.
(3,893 Views)
