How to create a degaussing function using Labview and RS232 controlled DPDT switch?
I am trying to create a degaussing function for a magnet using LabView.  I am using a RS-232 DPDT switch.  Any tips or ideas that could help lead me in the right direction?
Thank You
(3,994 Views)
It's not very clear what you are trying to do. Can you elaborate a little more on your question? You could also provide the specifications of the RS-232 DPDT switch.
(3,970 Views)
Sure. I am using a R25DPDTCNRS relay connected to 2 power supplies and 2 magnets.  I am using the relay to change the current direction through each magnet.  After I switch the current direction, or just turn the power supplies off, there is a remnant magnetic field.  I'd like to create a LabView function using the relay to degauss the magnets to as small of a magnet field as possible.
(3,960 Views)
What have you done so far? Have you studied the manual? It looks like it does use ASCII commands but there are a lot of examples (though not in LabVIEW). I would suggest you get familiar with the Byte Array to String and its compliment the String to Byte Array. The type Cast can also be used. Lastly, a string control can be set for hex display if you want to use that for the input to the VISA Write.
(3,947 Views)
