How to decompose a 4 line string?
How can I split a 4 line string and then be able to parse a certain part of the decomposed string?  I am using a Hart Scientific 1529 Thermometer.  It has 4 channels and i've attached some sample data that I've collected along with the .vi I am using for collection.
The data is gathered 4 lines at a time once per second for each measurement.  I tried wiring a "string subset" followed by a "Fract/Exp string to Number"  (to the Serial Read) but that gave me the 4 values of the temperature one after the other.  I would like to have each channel output to an individual numeric indicator (4 total).
(4,178 Views)
It appears that the channel number is part of the string. Use the string subset to get this and wire it to a case statement. Each case would have a different indicator inside.
(4,170 Views)
Thanks for the advice.  I can see how I will be able to use the case structure using the string subset to create 4 cases (if i just keep the channel string). But then how can I display each individual value for that channel (won't the string still contain all 4 values)?
(4,148 Views)
What don't you understand? I said you would put separate indicators in each case statement. Below is an image of how the first 2 cases of a single case statement would be done.
This is pretty elemental LabVIEW programming. You should look at the resources for Learning LabVIEW at http://www.ni.com/academic/lv_training/how_learn_lv.htm
Message Edited by Dennis Knutson on 07-29-2008 12:12 PM
(4,143 Views)
Yea i figured it out once I tried it.  You had the impression you had explained what you were thinking.  I guess it's clear if you use LabVIEW everyday.  Thanks very much for the advice.
(4,137 Views)
