How to determine GPIB-ENET firmware version?
I have several of the older GPIB-ENET units. I see the latest firmware binary on the FTP site is A5. I'm pretty sure our units have olders revs since they were installed several years ago. However the manual says to only update the firmware when necessary since there are a limited number of times the firmware can be updated.
My question: Is there a way to determine the device firmware version so I'm positive I need to update?
I notice the new EthernetConfig utility for GPIB-ENET/100 devices shows the firmware revision when you select the device. Can this utility also "see" older GPIB-ENET devices and show the firmware revision for these older devices as well?
(3,306 Views)
Could you email in to the technical support deparment? You can go to www.ni.com/ask. We'll try some alternatives.
DiegoF
National Instruments.
(3,306 Views)
