How to develop an application like a nispy application?
Currently, I use GPIB card of national instrument, and I hope to utilize some functions in NiSpy application.
However, I don't have NiSpy source, so I try to develop an application like NiSpy.
Is there anyone who has the source of smiliar application to NiSpy?
Please, help me >.<
(4,319 Views)
I'm  not sure why you want to do this.
NIspy does have a LabVIEW API (and presumablly a LabWindows/CVI interface) For Windows only.  What OS and Language are you trying to re-invent the wheel in?
(4,311 Views)
OS : Windows / Linux / Unix / SunOS
Language : Ansi-C
I need the API developed with C, Could you attach the source on this web-site?
(4,290 Views)
I certainly cannot attach NI-source code. If I had access to it it would most certainly be under a NDA- I don't even work for NI.  Digging into the LabVIEW API all the functions are a very shallow hierarchy calling into the NiSpyLog.dll through Call Library function configured with a WINAPI convention and only a windows target is enabled.
You may need to "roll your own" to get cross platform performance.
(4,274 Views)
