How to disable/disconnect NI Scope channel(s) by IVI from TestStand
Hi all
After finishing scope acquisition I need to disable = disconnect scope channels. Idealy all of them.
I tried to setup attribute "IVISCOPE_ATTR_CHANNEL_ENABLED" to FALSE but this will disconnect channel only during next acquisition .
I tried IVI Scope Reset - but this will not disconnect channels.
I tried IVI Scope Self Test - but this will not disconnect channels.
I know that NI Scope Soft Panel could disable channels.
How I could do it from TestStand + IVI Steps
My configuration:
TestStand 2019
NI IVI
NI Scope drivers
NI PXIe-5105 (8 channels)
Thank you
 Peter
(1,467 Views)
Accepted by topic author JCC_(SK)
Here is sequence of IVI scope steps to disable (disconnect) scope channels:
  • Initialize Scope
  • Configure Scope - Un-tick every channel which you want to disable
  • Initiate Scope - this will apply configuration and start acquisition which we don't need
  • Abort Scope - return scope to idle state
(1,396 Views)
