How to do request/response from the serial port communication
I have connected my laptop to the HW which is communicating through RS232 and i want to extract possible request/response from the port. For example:
If i send
Request: 3B 16 07 xx xx xx
i would expect the response which will read approx 50bytes of data in format
Response: 3B 16 01 02 03 04 05 .................................................... till 50 bytes
Any information on how to do this would de really helpful.
Message 1 of 10
(8,241 Views)
What language are you using?  LabVIEW?  C++?  Ruby?  Java? etc.
Assuming you are using LabVIEW, look at the examples (Help->Find Examples).  There is a Simple Serial Write & Read that you should look at.
Message 2 of 10
(8,237 Views)
I am using Labview 2011. Ok Thanks, i will look into this.
I also needs to parse the response bytes, can you provide me any sample vi which does this so that i can get some info on how to do that?
Aniket
Message 3 of 10
(8,211 Views)
You can use the String to Byte Array function. Then it's simply a matter of using the Index Array to get the bytes you want.
Can you provide the make and model of the instrument? Did you search for dBm existing driver?
Message 4 of 10
(8,209 Views)
Hi Dennis,
Currently i don't have any model vi , but looking for 1 sample vi so that it's easy for me to proceed.
Can you explain me in a brief how to do this with some model vi.
And what do you mean by dbm existing driver?can you also share some info on this.
Aniket
Message 5 of 10
(8,202 Views)
Surely you know who makes the instrument and it's model number. You've already been given an example for generic serial communication.
Sorry, the dBm was an auto type correction mistake. You should use Help> Find Instrument Drivers to see if there is existing code for your specific instrument.
Message 6 of 10
(8,199 Views)
Actually the HW it's internal to the company which is manufactured and  used by them only, so it's not the generic one which you are looking for.
the HW and my tool will communicate through RS232 only which is serial comm.
Do you have any sample vi which parse the data for the following bytes.
Aniket
Message 7 of 10
(8,183 Views)
Please try the functions I mentioned
Message 8 of 10
(8,173 Views)
Hi Dennis,
I checked with those functions but not helpful as couldn't able to get the required instrument driver.
I able to find out how to send request and response but stuck with the parsing one, can you help me with that as i have to parse 55 bytes of data one by one.
Message 9 of 10
(8,158 Views)
You would have to create your own instrument driver.
Are you using the example mentioned to send data? Did you change the string control to hex display? Do you get anything with a read? If so, you need to show what you receive. If you in fact get hex data back, then the String to Byte Array will work.
Message 10 of 10
(8,154 Views)
