How to find start charecter in serial communication
I am able to find end character but unable to find start character. Please explain me how to find start character with an example.
Thanks & Regards
Rams
(3,735 Views)
A start character, or preamble, is defined by the source. What is your start character? i.e., what are you expecting?
Richard
(3,720 Views)
Dear Arrow,
My start charecter is "*02" it is defined by the source. command format is *02|data|*03|OD|OA!
(3,701 Views)
Not sure where your problem is. There are functions to search a string and you just have to specify what you are searching for. It would seem that this is a hex string so be sure to click on the string constant/control and select 'Hex Display' before you enter the 02 value.
(3,692 Views)
Yeah, I'd use Match Pattern to pick apart the message.
Richard
(3,682 Views)
