How to get customInfo value from range table?
How can I get (read) the actual value of
the customInfo field in a range table?
Also I would be interested in a sample code that
shows how to use that value as a format string for
a instrument command.
Thanks in advance,
best regards,
Marcus
(3,379 Views)
i think your talking about the following lines in the ivi.h
typedef struct
    ViInt32                     type;
    ViBoolean                   hasMin;
    ViBoolean                   hasMax;
    ViString                    customInfo;
    IviRangeTableEntry          *rangeValues;
            /* the end of rangeValues[] is marked by the entry  */
            /* IVI_RANGE_TABLE_LAST_ENTRY                       */
    } IviRangeTable;
Tutorial using IVI Range Table [broken link removed]
(3,366 Views)
Unfortunately the tutorial does not answer my question.
However I could resolve the problem in the meantime.
Just use the following code:
(1) Get address of desired RangeTable
status = Ivi_GetStoredRangeTablePtr (vi,
attributeID,
&tabletest);
(2) Read the customInfo string
custInfo = tabletest->customInfo;
Thanks to all,
Marcus
Message Edited by Marcus3967 on 07-07-2005 03:42 AM
(3,362 Views)
